Is this an AfterMarket Cable?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2007, 11:25 AM
I have been having trouble locating a bracket to mount my TH350 cable to my Carter 9635 carb and Edelbrock 2101 Intake. Aftter many searchs on this topic I have come to the conclusion that I may have an aftermarket cable that was used for improved shift adjustment. Can Anyone tell me if this is an aftermarket cable? And if so what bracket do I need?
ID:	24239   Click image for larger version
Old 09-16-2007, 12:44 PM
HotRods by Al
buy an aftermkt bracket,cut ,weld,beat,bang,youll just have to fix it! But thats just what I do, just nuts & bolts,make them conform,try it
Old 09-16-2007, 12:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that is an old GM design cable...
I've not seen one of those cables in years.
Old 09-16-2007, 01:36 PM
How many years? This is a 69 GMC 1/2 ton.
Old 09-16-2007, 03:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
about that early. I believe it is the first design.
You need a bracket like the one pictured. I dug this up in my "pile O stuff" here at my home work shop.
Bolts onto 2 intake manifold bolts. The plastic piece slides for adjustment on the bolt.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
HELP , My Firebird is dead IGENFIREBIRD Electrical 29 04-23-2007 03:24 PM
