Aftermarket Electronic Dizzy/Mopar - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2011, 08:38 PM
WesTXmc's Avatar
OFMF
Last journal entry: 1970 Monte Carlo
Evening Folks!
Installing a aftermarket "Pro Comp" electonic Dizzy in my 65 Fury III that I just stuffed a 440 in. This Dizzy has 2 wires coming out of it and is of the "self contained" style - ignition module is "on board" and just requires a coil. The manufacturer's instructions say to simply hook both wires to the coild and it's ready to run? Common sense tells me that the RED wire from the Dizzy goes to the + side of the coil and the BLACK wire from the Dizzy goes to the - side of the coil. Does that sound correct? Anyone have any experience with these style Dizzys? I bought it from 440 Source but it came with no "wiring" instuctions.
Another thing I noticed, using a 12 volt test light, with the key on, I get power from both the + and - sides of the coil? Is that right?
I am electronically challenged - any help I can get is greatly appreciated. Thanks in advance.
Pat
Old 10-12-2011, 03:48 AM
EOD Guy's Avatar
Never used that one..... seems like one wire would be switched power from a 12v source, and another for a tach?
Convert Electronic Q-Jet to Non-Electronic cobalt327 Engine 13 10-31-2009 11:22 PM
Opinions Please... Aftermarket Electronic Ignition tattooster Engine 21 10-23-2007 10:39 PM
setting the gap on a points type dizzy... makes me dizzy... JJ350 Electrical 6 04-04-2007 02:55 PM
setting the gap on a points type dizzy... makes me dizzy... JJ350 Engine 6 03-27-2007 03:33 PM
mopar points to electronic conversion legionlleh Engine 3 03-09-2007 10:04 AM
