Aftermarket Fuse Blocks? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2011, 06:27 PM
adam83's Avatar
My fuse block on my 68 GTO has had it I think, Im looking for a new one, I posted a wanted add, but I was wondering if anybody besides Year 1 makes reproduction fuse blocks? Year 1 does, but they wont sell it separate from the wiring harness, and I just dont have an extra $600 to spend right now. Is there anywhere else I should try?
Or, is there just replacement metal tabs I could buy to put in my current block? I think the problem with mine is surface rust on the little metal tabs, and the fuses have to be positioned JUST RIGHT for current to get through.
Old 03-04-2011, 03:43 AM
EOD Guy's Avatar
Use a coffee stir stick and some 100 grit sandpaper and fix it
Old 03-04-2011, 07:16 AM
I haven't been able to find the Packard 56-style fuse terminals either, but here's an article about how to convert your older glass fuse block to a newer blade-style ATO fuse block. You CAN get the terminals for the ATO fuses.
http://www.rowand.net/shop/tech/GMATOStyleFuseBlock.htm
Old 03-04-2011, 07:54 AM
delawarebill's Avatar
fuse block
when i built my bucket i used a fuse block for boats. marine store has then... figure if they are for a boat i can't hurt it. and they are the blade type.
Old 03-04-2011, 10:01 AM
adam83's Avatar
Can I take the fuses out and 'pop' the tabs out or are they permanently fixed in place?
Old 03-05-2011, 08:23 AM
302 Z28's Avatar
The connectors usually have a tab that sticks out to the side that keeps the connectors captive in the fuse block. Find something thin to push down into the slot that the tab rides in and you should be able to remove the connector.
Vince
Aftermarket Blocks Camaro2 Engine 1 11-18-2009 03:26 PM
fuse blocks zz71s Electrical 3 04-27-2008 12:18 PM
Pre-Wired Fuse Blocks Harley Monster Electrical 11 09-12-2007 01:34 AM
Need info on the best aftermarket Fuse Box. 90TR Hotrodding Basics 5 07-16-2007 04:17 PM
aftermarket blocks hause Engine 1 09-16-2005 03:07 PM
