Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Aftermarket IFS vs S10 chassis?
Old 02-04-2012, 09:13 PM
stich626's Avatar
stich626 stich626 is offline
Last journal entry: The TwoTonShu #10
Originally Posted by slingshot60
Sooo... use my '96 Roadmaster brakes and fit them with Camaro 1LE rotors?
use the b body spindle,
an aftermarket upper a arm
le1 rotor AND calp.. the b body rotor is not the same thickness as the f body le1
and you sould be good to go.. you might want to check.. but I thought the b body parts you needed only went to the body change over not all the way up to there end..
iirc its 77-90 could be wrong..
better question.. why not use the b body frame,, is it to wide?
dads got a 49 willy p/u and a 51
