Aftermarket oil pump pickup clearance issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 02:46 PM
So I got this aftermarket pickup with the pan I ordered. The pan is a 5QT claimer style with 2 trap doors.
I figured I would use the pickup that came with the pan, but when I measured the clearance with some clay I am at about 3/4" with the gasket, maybe just a little less with what bending I can do on the pickup. Can't bend it much because it's got the bracket that bolts to the oil pump body.
1. Should I just ditch this pickup and use the stock pickup?
2. Should I cut off the bracket from the aftermarket pickup and just weld it to the body?
3. ?
Thanks for the help
Old 01-23-2012, 03:47 PM
3. ?
Thanks for the help
If #3 is the option of sending it back, I'd choose that. If you modify the thing and it ever fails it will be on your dimes.
Bogie
Old 01-23-2012, 04:47 PM
hey..is this goin on a stockcar, or is it a circle track pan...if so that is pretty close..
Old 01-23-2012, 04:57 PM
oil pick up
i have always keep pick up 1/4 to 3/8 in off bottom of oil pan.
Old 01-23-2012, 05:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Bogie
It might be the wrong PU they sent, I'd find it hard to imagine there was no PU to match the pan.
Old 01-23-2012, 07:21 PM
tidiums
tidiums, It's a street rod, not planning on racing.
I think it's meant for a high volume pump, I have a standard volume M55. Not sure if a HV is taller than a standard pump.
I am shooting for 3/8" clearance. I think I'll try ordering another pickup...
Old 01-23-2012, 07:26 PM
engineczar's Avatar
A HV pump is about a 1/2" taller than a standard pump. I would send it back and get the right pickup.
BSE Racing Engines
Old 01-23-2012, 07:27 PM
You could be right on; that high volume pumps have about 1/4 to 3/8's more length to the pump cavity.
Bogie
Old 01-23-2012, 07:32 PM
Yep
It was one of those buy the pan and the pickup is free type deals...
It's supposed to be a 7" deep pan but I will measure to make sure. Maybe someone knows a part # that works.
Oil Pump Pickup Clearance V3500 Engine 10 09-08-2009 08:43 PM
aftermarket pickup tube installation dirtinla Engine 1 11-29-2008 05:08 PM
header clearance issue with AC Brackets BuddyJarvie Engine 4 09-07-2007 11:15 PM
Clearance issue... staleg General Rodding Tech 6 04-25-2007 05:15 AM
Aftermarket pickup beds jmi Body - Exterior 2 07-09-2002 02:43 PM
