aftermarket tailgate ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2010, 11:22 AM
Wiki Edits: 31
I recently bought a 1998 Ford Ranger 4.0L 4x4 automatic extended cab. loaded ect... needs some rust repair, like a tail gate and a lower door patch on the pass side... I'v been looking for used tail gates but can't find anything thats decent.. cost from Tasca Ford parts is $219+ ship, and an aftermarket is around $100/ shipped.
if the Aftermarket will fit good. I will buy that, but if it won't fit well, I'll go for the OEM Ford peice..
Old 06-12-2010, 11:39 PM
327NUT's Avatar
Take it for what its worth but what I've heard is that ALL aftermarket sheet metal is made "Offshore" and its crap. Thin gauge and poor fit, I would keep looking for a used OEM piece.
Old 06-13-2010, 12:27 AM
Wiki Edits: 31
that's what I'v heard too. just was hoping there was an exception to the rule.. I'm probably going to buy a good door and swap the guts, because of the fitinment issues I'm sure will arise from a patch panel I know is made in China ( LMC says so ).. my experience with aftermarket Ford Ranger parts only goes as far as the plastic front end peices, and a front bumper that fit well. the bumper was actually made by Certi-fit ( or as most say Sorta- Fit ) but it fit well, altho the chrome wasn't OEM quality it was still good..
I'v found lots of decent used 1's, but they all have dents to the top of the gate, which on a '93+ Ranger is pretty well non repairable due to the body line being right there
Old 06-13-2010, 11:36 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I can't remember where i got my tailgate from it has been a few years. But it did fit decent and looked good till i was driving down the road and the whole side of it came apart and fell off hit the ground. Never used it again but it just wasen't welded properly from the factory i guess. It's just hard to get good after-market body parts that work well. I think most will need more work before you can install them been my experience anyway.JMO I would pay the $119 difference get a factory piece if i could if i were you ,JMO
Cole
Old 06-13-2010, 01:29 PM
Wiki Edits: 31
yea. I gotta figure up the savings from getting it from Tasca Ford parts, or just getting from the dealer parts dept.. list price is $333, and it's $219 from tasca, but shipping might be killer... gonna go to the u pull it just to see if I can find anything good there first tho..
Old 06-13-2010, 02:44 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I've used two on f-250s and they didn't fit too bad. They are a little thinner but better than patching a rusted one. I would think with a little adjustment you should be able to make it fit ok. The after market hoods on a chev pickup -99 fit as good as factory.
Old 06-13-2010, 09:53 PM
Wiki Edits: 31
to be a good spammer, you could at least work the links into your 'story'.. it was a nice try but... spammer ( luoxiaosang ) above reported
Old 06-13-2010, 10:34 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Have you tried car-part.com ? I found lots of tailgates and doors for rangers..as well as other pieces..gotta be some good ones somewhere..!
Sam
Old 06-13-2010, 11:18 PM
Wiki Edits: 31
I did check Car-part. most of the tailgates that had the 000 damage code were more than a brand new OEM peice from Ford. and outside of my state.. I checked with a large recycler that ships state wide and is tied into the Car-part database, and they have 3. 1 is mint that is $300 ( more than I can get a brand new 1 for ). 1 is decent ( dents in the top region ) and the other is a " work gate "
but I also just remembered another yard that is closer/ tied into the Car-part search and searched them, and they have a mint 000 damage code 1 for $250, and 1 with surface rust starting on the lip for $100, and several work gates for $50 and $75. so I'll have to go and make sure there as good as they say they are.. the workers at that yard give the wrong parts all the time, and are not very pleasant
Old 06-14-2010, 09:42 AM
A lot of times doors and tail gates or deck lids are MORE than the new OEM because they are sold as an assy. The tail gates are stolen all the time, soooooo the wrecking yard sells it as an assy priced accordingly compared to the OEM gate, latches, handle, access panel, etc. If you added up all the parts the used is cheaper.
Go for the aftermarket but be ready for a less than stellar fit and finish and possibly a shorter life if you use it hard.
That is the fact, period.
Old 06-14-2010, 09:55 AM
Wiki Edits: 31
I figured that's why there more.. but some on Car-part are over $1,000.. those are some expensive tailgate guts..
the tailgate that is on it works fine so it could lend all the 'guts', but it's rusted out bad on the bottom and it's perfect and dent free on the top. I could probably cut apart a gate damaged on the top and patch it with clean metal on the lower to fix mine, but that's a lot of work when factory gates are $240
nobody can steal my tailgate.. truck has a hard tonno cover that goes down over the tailgate and has a lock. so it effectivly locks the tailgate
Old 06-14-2010, 11:06 AM
One possible Plus is if the paint's the right color, slide it on and you're done.
Old 06-14-2010, 07:37 PM
Well using sheet metal from all over in my work and hobbies I can tell you there is a difference. I have seen 3 grades Euro spec, American spec, and Chinese.
The quality in stamping, welding, holding and weight are distinct. Buy a good USA made product and you will be fine.
Plus some products just cant overcome years of use and no real fitting.
Old 06-15-2010, 12:17 AM
Wiki Edits: 31
it would be very unlikely to be the same color.. my truck is 2 tone, the main color ( vermillion red ) is a pretty common color that was used in 1998 and 1999 and XL/ fleet trucks to 2001. my previous truck, also a 1998 Ford Ranger ( but was 2WD 4cyl ) was also Vermillion Red.. but my new truck is 2 tone with a gun metal grey on the bottom.. lots of these trucks got painted Toedor red with the 2 tone, but not many vermillion red.. Vermillion is the solid bright red, and toedor is the metallic darker red
Aftermarket Anti-lock Brakes?????? coda618 Suspension - Brakes - Steering 1 10-10-2008 10:14 AM
Tailgate for 35 Ford pickup? Kruzin Karl Body - Exterior 2 03-02-2006 06:27 PM
Aftermarket spring cups or let the springs rest on a shim? sizemoremk Engine 3 01-13-2006 02:51 PM
tailgate replacement help needed brian12c Hotrodding Basics 2 11-20-2005 11:33 AM
