| View Poll Results: Turbo or Supercharger? | |||
| Turbo!! |
26 | 37.68% |
| Supercharger!! |
43 | 62.32% |
| Voters: 69. You may not vote on this poll | |||
LinkBack | Thread Tools |
Try driving a pre-war Willys coupe gasser to a rod run some time and see who wins the ooing contest!!
compare stock to stock
turbo: grand national, srt4, wrx sti, talons,omnis, and others supercharger: late model monte carlos, bonnevilles, and thats all i can think of right now i think those stock turbo cars are a hell of alot faster than the stock supercharged |
Ive said it a million times.
Its weather you like the big power n looks or big power n stock look. To me, nothing says wow more than a belt drivin, whinning like a grandma with arthritis belt drivin blower. HG
And you're right ... there's absolutely no comparison
plus they don't look all that hard to install J |
Doesn't the Ford modular engine have a roots option? I'm pretty sure a friend of mine got the roots SC on his '04 Mustang Cobra.
My engine builder and me had this conversation a week or two ago and his comments were something like this. Turbos are fine if A you have room B you dont mine the high underhood temp C dont mind the extra weight of plumbing under the hood D cost of haveing the tubing made ( or time if you can weld aluminum at home )
I wanted to do turbos on my car but after all that and seeing a friends f2 prochargered acadian im seriously tempted to go that route . Roots blowers always have a place in my heart just it pains me to think of cutting my hood Regards Mike |
I don't know much about turbos but I was reading some other comments in this thread and someone said you can tune a turbo so it has no lag. Where as a S/C you just slap on there and adjust your timing and there you go. I'd probably have either but I've always loved superchagers, they make it look like you have something powerful under (or over) your hood. |
Well the issue with turbo lag is eliminated when you "brake torque" at the line. When drag cars have turbos, they spool up at the line so when the light turns green they are leaving the line with near full boost.
True on the part of difficulty, SC is much easier. |
A properly setup turbo system will experience minimal lag. Lag is a result of low velocity due to both/either a turbo that is too large (meaning piping/inlet is too large for the volume) and an overall system that does not promote smooth airflow (meaning sharp curves, ridges, etc).
If you build a turbo system that is both efficient in size and airflow pattern, you will experience little lag.
Bringing history and technology together. |
