Ahh yes, choosing gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2003, 01:14 PM
JRS1967's Avatar
New Member
I have a 1967 Chevelle and I am wondering about what gears I should put in my rear end. I am running 3.33's and my car currently and it will pratically idle in overdrive at 65mph. I am running a 283 and I am estimating it's horsepower output to be around 275. I am running a 700R4 transmission and my top speed is around 100mph, maybe a little more but my speedometer is not set correctly yet.
So my question is, do I put in 3.90's or 4.11's? Or is that too high and I should just run 3.73's instead? I still need a decent highway speed but the car is used mostly for crusing around town, not a whole lot of highway miles. I would like the car to run around 70mph comfortably.
What gears do I use?
I need a reply ASAP because the car is going in this Friday
Cheers
Old 07-22-2003, 01:32 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I would use the 3.73's. With your 700r, you should be fine @ 70.
Old 07-22-2003, 07:58 PM
302 Z28's Avatar
There are various rpm/gear calculators on the net to assist you with this subject. I got one from this website in the Knowledge base area. On my street rod I will be using a 700R4 with a 3:70 rear axle ration. The OD ratio in OD is .7, with 30" rear tires at 70mph it will be taching about 2100rpm.
Vince
Old 07-24-2003, 04:19 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
I once put some 4:11's in my GTO ...it was real painful just running around. Don't get me wrong, it was FUN on the on-ramp to the freeway, but painful from there on. I have a set of 3:73 in my vette now, and I wouldn't change them for anything!(were talking city driving here) ...My 2 cents. ...Mark
Old 07-24-2003, 05:26 PM
Hollywooding's Avatar
Canknuckle Head
Everything You Need
Poifecto
Go here and all your questions shall be answered
Hollywooding :cool:
