Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ahooga Horn with Led Momemtary Button Control
Old 01-14-2013, 08:15 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
It's called a bosch type relay, avail in just about every auto parts store, Radio Shack or....... I get mine from junked cars .... your looking for the five pins. On the side of most relays you will see the dia of what terminals are what....
To make the connections to the relay, you can buy a socket, I use female spade connectors, to tie the hots together, I use a spade connector, a short run of wire from both terminals into one end of a butt splice, the other end of the butt splice goes to the hot etc....
on the switch, just twist, then solder, them together and cover with heat shrink.
