Hey, welcome to Hotrodders Bulletin Board.
![]() Any idea how many amps the Ahooga Horn draws? If it's more than the switch is rated for, then it would be best to use a relay or a beefier switch. Hope this helps... |
I'm not sure, the package hasn't arrived yet.
I talked to 2 different guys at the mfg. 1 said 3amps, the other said 9amps. Both are under the 10amp switch, but I'm obviously not going to get any help from those guys if they can't even give me a definitive answer on the amps. |
This is how I'd wire it. I have used those switches before and they won't carry many amps for very long, before they start getting hot and make the housing get soft from the heat then they fail, the contacts will take the current but not the housing. I like to use the gorund leg of the relay to function it..... This is a bosch type relay avail at any auto store or junkyard
| The Following User Says Thank You to EOD Guy For This Useful Post: | ||
DEATHTRAP (01-23-2013) | ||
I have four of these controlling the fwd and rear cameras on my truck...... I use telephone wire soldered to the small contacts, then strip the phone wire and wrap it around a larger gage wire, solder that, then slide a piece of shrink wrap over the entire thing..... works well. three years now on mine wired that way with no failures...... the first go around burnt two switches...
When you solder the contacts be quick..... the iron will melt the contacts out of the housing...... don't ask how I know this....lol |
Here is a source for some Stainless Steel momentary mini switches, they are about the size of a pencil eraser. I really like them and have used them on many mods, they hide very well...... My latest mod on my 67 Camaro.... the window cranks are the power window switches etc..... I put a mini switch on the side of the dash, with a series of relays, so that when you press the mini switch, the drivers side window crank controls the passenger window.... completely hidden and looks completely stock. I put another mini switch just above the window switch that unlocks the doors.
Harley Mini Push Button Momentary Switch s Steel for Custom Applications | eBay |
Oh, I was just going to use those little connectors.
Thanks for the diagram, that helps alot. I've never had to put in a relay. So I should be able to tap into my existing aux line for power to the leds without having to worry about a fuse it looks like? And I'll just have to use an inline fuse from the relay to the battery? Does that sound right? |
What kind of Relay to I need to buy?
And how do you properly tie in the 86 and 87 pin on the relay to go to power, and the NO and Ground pins on the switch? Are you just twisting the wires together or is there a better way to do it? |
It's always good to fuse all circuits, if your Aux source has a fuse you'll be fine not using an another fuse, those LEDs draw a tiny amount of juice and probably will smoke long before the fuse blows.
What kind of Relay to I need to buy?And how do you properly tie in the 86 and 87 pin on the relay to go to power, and the NO and Ground pins on the switch?Are you just twisting the wires together or is there a better way to do it?
It's called a bosch type relay, avail in just about every auto parts store, Radio Shack or....... I get mine from junked cars .... your looking for the five pins. On the side of most relays you will see the dia of what terminals are what....
To make the connections to the relay, you can buy a socket, I use female spade connectors, to tie the hots together, I use a spade connector, a short run of wire from both terminals into one end of a butt splice, the other end of the butt splice goes to the hot etc.... on the switch, just twist, then solder, them together and cover with heat shrink. |
I didn't know I could buy a socket for the relay either.
Great. Hey Thanks alot for all the info EOD Guy ! It's very much appreciated. You've really simplified something that may have aggravated the Piss out of me. Hopefully all will go well. Cheers.
| Horn button | Oilyrascal | Hotrodding Basics | 4 | 12-03-2012 04:01 AM |
| Need to setup push button for horn | Juicer28 | Hotrodding Basics | 1 | 02-15-2011 04:08 PM |
| Horn Button wiring,one,wire,two | fat40 | Electrical | 2 | 12-20-2006 04:27 PM |
| Horn Button on Lecarra Steering Wheel | djboen | Electrical | 2 | 05-22-2006 05:35 PM |
| Looking need exploded view of 54 chevy horn button | wy.miner | Interior | 2 | 03-24-2005 05:39 PM |
