Air bag / exhaust heat - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2008, 07:00 AM
Last journal entry: Body work
This is my first car with air suspension and I am a bit concerned about exhaust heat damaging the rear bags. The clearance is about three inches from the pipe to the bag. I wouldn't be as concerned if this car wasn't turbocharged as the exhaust might not be as hot. The pipes will be ceramic coated when finished so, that may help some. Do you guys think a heat shield between the bag and pipe would be necessary?
Thanks.
Ed
ID:	28406   Click image for larger version
ID:	28407   Click image for larger version
Old 03-06-2008, 10:42 AM
I would put a heat shield on the exhaust leaving 0.5" or more between the exhaust and the heat shield. Weld it on and have it coated with the exhaust.
Edit: you also should put some heat shielding on the fuel lines.
Old 03-09-2008, 07:52 PM
Vortech 4.3's Avatar
jack of all trades
i would be more worried about the fuel lines. the bags, i bet there would be no problems. as was said, a simple shield would not hurt, and would not be ugly.
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 03:18 PM
32 chevy air bag front suspension kWIK32 Suspension - Brakes - Steering 2 06-28-2007 12:24 PM
Heat and Air Conditioning Systems Woody31coupe Interior 5 09-10-2006 07:40 PM
over heating delsman Engine 38 09-14-2005 09:32 PM
Air shock heat shield HHStang Hotrodding Basics 1 06-29-2005 09:22 PM
