Air Bag Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2010, 08:20 PM
Air Bag Leak
I recently bought a car with airbags up front and the compressor is wired up to a toggle switch under the dash. With the bags up, the pressure guage reads 90 psi. I usually drive the car once a week and every time I get in to drive it, I flip the switch and the compressor runs for about 10 minutes even with the guage reading 90 psi. I don't know the size of the tank. Is it normal for the compressor to run so often?
Old 12-11-2010, 05:24 AM
deadbodyman's Avatar
Wiki Edits: 11
maybe.....the first thing you should do is get some soapy water in a pump bottle and check all the fittings for leaks...
Old 12-11-2010, 08:35 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
little compressor/large tank=10 min,
10 min is a long time, are you sure its that long?
the comp my be going bad
Old 12-12-2010, 06:28 AM
Wiki Edits: 11
If it is the comp ,they are very ez to rebuild....
Old 12-12-2010, 07:57 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Have you checked the relay could be bad / stuck JMO. Or the bag /line could have hole rubbed in it/fitting could also be leaking . Or it could be the compressor.
Cole
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 135 11-01-2014 09:49 PM
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 03:01 AM
Lexus air bag suspension? gas_guzzler Suspension - Brakes - Steering 0 05-12-2010 04:11 AM
'65 volvo 122s wagon - DIY air bag system? 122s Suspension - Brakes - Steering 8 11-02-2007 01:55 AM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 04:34 AM
