Air Bag Not Deflating - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 08:07 AM
10mikeymike's Avatar
I have a 37 Ford street rod with an Air Ride Technologies ARC4000 system. Occasionally it will not exhaust the air in the left rear bag. It seemed like if I played with the switch it would eventually work. Recently, it did it again. This time I swapped the switch with another one and it didn't solve the problem. In fooling around with the switch, I now have the car at its maximum height on that location. Since the problem is obviously not the switch, I can only imagine it's the valve block. Is there a simple way I can exhaust the air on the problem location? I plan to call Air Ride Tech. tomorrow but in the meanwhile, has anyone else experienced a problem like this? Is it possible to buy the valve blocks independently?
Old 07-27-2008, 08:38 AM
poncho62's Avatar
Wiki Edits: 5
I don't know much about those, but I wonder if you have some dirt floating around in there.....and it is blocking a passage now and then.......
Old 07-28-2008, 07:27 PM
i am guessing you have already contacted air ride...but if not,the switch activates the solenoid which opens to let the air out...it could be the solenoid since you have proven the switch is not faulty.also,the air ride system really is touchy about the grounds.if the grounds are not good,it can cause a multitude of problems
Air Bag Suspension J Cal Suspension - Brakes - Steering 0 01-16-2008 07:19 AM
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 07:41 PM
1990 lincoln mark 7 leaky right front air bag suspension fasteddiesage Suspension - Brakes - Steering 3 10-06-2006 10:49 PM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 08:44 PM
air bag sussspension high octane Suspension - Brakes - Steering 1 08-14-2003 11:06 AM
