air bag setup on 50 merc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 09:10 PM
Hi
Having a ton of bottoming out on my 50 merc. Has original front end with dropped spindle/disc kit on it from fatman. Here in NY we have some rough roads. There is a good skid plate under it but i am afraid of damaging other parts let alone it scares the crap out of me when I hit a bump.
So what are my options as I like the way it is from a stance standpoint. Airbag setup? Dump the spindles? I cannot continue to drive it as is. frame is too low to ground to drive. What can I do?
Can provide pics as soon as daylight hits.
thanks!
Kevin
Old 09-18-2006, 10:53 PM
BAG IT! You can enjoy the same stance when cruising around town and when you need to lift it up a little bit for a certain location you can. Your car will basically be more reliable to you. You will need to purchase nice quality products and have a very quality installation for the setup to be an everyday reliable vehicle. Your Merc will get superlow and raise almost to stock height. I am a huge advocate of air ride as it is a huge staple to my business, so maybe I am a little biased. I think that air ride would be a wise decision for anyone that enjoys a low vehicle and the practicality of being able to drive your car. I will be more than to help you out with any of your questions.
Heath
Old 09-19-2006, 05:24 AM
do you have any recommendations on what type of system/manufacturer I should be looking for? How about a rough idea on cost with installation?
Thanks
Old 09-20-2006, 12:27 AM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
OK, it's a little newer than yours...
Kosmo, take a look Here
When I bought my bags and made my own mounts Air Ride did'nt have a kit for the Fifties cars. I gave the rep at K-zoo my cardboard patterns, and suddenly they now have a kit....
If you just want up and down, buy the bags, and plumb it with hardware store ball valves as I did. You can rig up an A/C compressor like mine to cycle thru a standard air compressor switch, to fill whenever the motor is running.
I have individual valves on each bag, on a common manifold made from plumbing tees and short nipples. One valve on each end of the manifold allows for filling, and the other allows for dumping.
Doc
Old 09-20-2006, 11:47 AM
whats kzoo>?
What kind of cost am I looking at for a bag setup...
thanks
Old 09-20-2006, 12:38 PM
Where's my Sawzall?
Wiki Edits: 2
I should have been clearer...
Should read ' I gave my patterns to the Air Ride company rep at the NSRA Kalamazoo Street Rod National event'...
I have about $60 each in the front #2600 double-convolute bags, and about $45 each in the rear #1700 tapered-sleeve bags. I got my valves for $5 apiece at Menards, and misc. plumbing fittings ate up another $30.
By the time I figure incidentals like the rubber air lines I got thru Harbor Freight to hook it all up I figure I have less than $400 in the whole system, including the steel for the bag mounts I fabricated.
Doc
Old 09-20-2006, 05:52 PM
Hi
So what is the company you gave the plans to or has the kit? I am not that handy to do something like this but trying to get all details to have someone do it hopefully in NY.
thanks
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
air bag replacement? totalled? grouch Hotrodders' Lounge 22 09-19-2005 07:20 PM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
'50 Merc Lead Sled jj$hide Introduce Yourself 3 12-03-2004 05:08 PM
Air bag suspention 1970CDV Suspension - Brakes - Steering 1 04-25-2002 04:18 PM
