Air bag suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2006, 01:05 PM
Air bag suspension
This will be my first time to build a full custom air bag set up in my 83 gmc sierra 1/2 ton longbed. i need to know what to do to get started. like what parts should i get first and what brackets and all the frame cuts and bed cuts. come on help me out this is a long term project and lots of money
Old 03-10-2006, 02:34 PM
GoneNova/406's Avatar
actually i have not done this job yet myself but would if i could afford it.its not a bad job at all if you have access to the needed tools.if you just punch in air lift suspension on your computer you should find many companies that sell these air bags and have all the instructions you need.for more info punch in air bag suspension articles in truck or 4x4 magazines.shold find everything you need
Old 03-12-2006, 12:08 PM
lowedlac's Avatar
i have not bagged a truck yet but I do have airbags on my caddy that I did myself with the help of my cousin, so the first thing you have to deciede is what kind of setup you want to go with, air ride has nice setup's and how much space do you have to work with, what kind of tank you want to go with, the heavier the truck the more air you want, you need one compressor for every three gallons of air or you'll be waiting 5 mins to hit on switch and thats another thing how many switches do you want 2,4,or 10. I have ten and thats the way to go. Also air ride makes a bolt on airbag kit for the rear end of chevy trucks no cutting the frame of body and still drop about two or three inches from the ground. try suicidedoors.com,airride.com or go pick up a mini trucking mag. and find everything
Old 03-12-2006, 12:18 PM
I'd really suggest an engine driven compressor instead of an electric one particularly on something with that amount of room under the hood. First off no annoying "buzz" from a compressor and secondly the amount of cfm's from an EDC will fill that tank up in no time.
Old 03-12-2006, 08:35 PM
lowedlac's Avatar
thats true if you can spare about 500 dollars or more for one. And with a non factory stereo you cant here any buzzing
Old 03-13-2006, 07:30 AM
A mini York a/c compressor which can easily be mounted on most engines runs around $100 from just about every retail autoparts chain, the clutch $120 and add maybe $40 for the mouting bracket which several people now make or you can easily fashion yourself. Or you can run to a junkyard and find these parts on most early 80's VW Rabbits for a fraction of that. Never have to worry about duty cycle and your tank is full in under two minutes. Get a decent 200psi electrical compressor and you're looking at $225 or so anyways and if you need two you've just exceeded by a long shot the cost of installing the EDC.
Old 03-13-2006, 05:05 PM
lowedlac's Avatar
or you can just go all out and get a couple of nitrous bottles have about 5000psi and hop the whole truck right off the ground about five feet
this truck has one inch steel lines 3/4 valves and about 5200 psi of compressed air. thats the way to go. BIG.....
ID:	10760   Click image for larger version
Old 03-15-2006, 02:42 PM
Thats actually 1" Hydro line and he is running 16 3/4" GC800 valves I believe.
Engine driven is the only way to go if you want to play alot.
Old 03-18-2006, 01:22 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
5200 psi? Ummm...I am gonna guess about 500psi. There isn't a bag on the market able to take 5200psi. Also that isn't a nitrous tank, that is a nitrogen tank with 3/4" GC800 valves. Those aren't steel lines either. They are high pressure hydraulic lines with crimped ends.
I am seriously doubting that he is wanting to launch his car 5' off the ground.
Later,
WEIMER
need advice/ tips on installing air bags in a 1952 chevy coupe with stock suspension Kuztmchev52 Suspension - Brakes - Steering 7 03-07-2006 12:52 PM
air ride suspension PaulNJ53Ford Suspension - Brakes - Steering 6 01-13-2006 03:45 PM
Air bag concerns scholman Electrical 13 12-08-2004 11:29 PM
Need help installing the right size Air bag on 1952 chevy coupe stock suspension. Kuztmchev52 Introduce Yourself 1 07-15-2004 12:00 AM
69 Camaro Air Suspension (bags?) Front G_Ecker Suspension - Brakes - Steering 2 12-24-2003 03:50 PM
