Air Bags get Traction? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 08:03 AM
i am building a restomod that goal is all around driveability. '61 full size Pontiac nearly 4,000 pounds. rear suspension is stock design 4 link which is a good design. i have tubular rear control arms with poly bushings to replace stock channeled arms.
i am considering replacing coil springs on all 4 corners with air bags for ride comfort and flexibility. properly setup, these suspensions have been proven to be able to handle fantastic, and of course cruise like a magic carpet.
i'm wondering though.... what is the effect to traction at launch?
527hp/550tq with TKO600 tranny & 3.90 posi. tires are only 245, so i am traction limited, unless i put slicks in for a 1/4 visit.
Old 02-14-2008, 08:00 PM
should be fine
should be fine you might if you can but a little more are in passenger bag and raise the front up. Next time you get tiers you might try a drag radial. I have a 55 with 235 bfg and get one wheel up.
What air bags setup is needed for a 55 Apache? Tri5Nerd Suspension - Brakes - Steering 5 10-23-2006 04:55 PM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
air bags srs xmodracer2006 Introduce Yourself 2 08-19-2006 07:24 PM
Putting Bags on a 54 Bel Air SoLow54 Suspension - Brakes - Steering 2 04-11-2004 05:20 AM
installing air bags on a64 cadillac one64cadillactramp Suspension - Brakes - Steering 6 03-21-2003 01:57 AM
