Originally Posted by deadbodyman
Tony ,Please explain 4 way independent system...Also,what would be best ,two tanks or four?
I think what he is talking about with a 4 way independent system. Is that you need to install this type system so you can control all four corners of the vehicle. Someone correct me if i am wrong. And another thing when installing air bag systems is to double check and make sure you have the bag mounts located in the right position for optimal results when lifting and lowering your ride,( Make sure everything it's clearing everything) And IMHO i really don't think you will need 4 tanks.JMO What size lines are you thinking about using?
Cole
