Air bleeds Holley HP (idle & main) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2006, 07:38 PM
Bumpstick's Avatar
Hammer and a torch
Did some searching but really found nothing that I`m wanting to know... What I have is #72`s in the idle circut and #32`s in the main circut... The problem is the throttle valves have been drilled to 3/32`s to help compensate for a low vac cam (this was for a previous engine with a larger solid roller cam)... When I put it on my engine its to lean... I can cover all 4 air bleed jets and it stablizes almost perfect so I just tried the much smaller #32`s (just switched the mains to the idle and vice vs...) It idles basicly perfect now (except for little or no effect from the mixture screws...?), but I am concered that the main circut will be much to lean... Should I just get another set of #32`s for mains to keep the calibration correct and then play with the idle air bleeds...?
I almost feel like just soldering up the #72`s and drilling them till I get it just right then take note of the drill size and get that size air bleed jet...?
thoughts...?
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
holley 4150 idle vacuum ????'s juveteach Engine 11 08-23-2003 08:42 PM
Idle Air Controller chevracing Engine 9 05-29-2003 05:43 AM
