Air bubbles in p.s. pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2005, 03:57 PM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
I just recently installed a new steering box and a new p.s. line to my existing pump. Now I have air bubbles in the pump. All I did was fill the pump up and started the car to work fluid into box, shut car and re-filled and started until steering started to work.Never ever had bubbles before this mess.Did I do something wrong?Is ther a way to do this properly or am I ***** out of luck and have to deal w/bubbs.?Plus now it makes that crappy big car steering sound like a caddy or delta.That humm sound.
Do I have to drain and re-fill???
Old 09-20-2005, 04:13 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
The bubbles will go away (or they should). I will lift the front tires off the ground and turn the steering wheel from lock to lock with the engine off to bleed out the air trapped in the P/S system. If you drive it around the bubbles should go away and the noise also. Good luck.
Steve
Old 09-20-2005, 04:18 PM
basic problem in fords......fix is
turn wheel (almost) to lock & hold for 3-5 seconds. Repeat process other direction. Do this 2-4 times, should clear the problem up. Do not hold the wheel all the way to the stop.....this will make the pump angry
Old 09-20-2005, 04:23 PM
New Member
Yup, when I replaced a pump before I didn't even bleed the system, it was like manual steering to get it out of the driveway at first. After about 2 trips into town and back, it acted normal. If the whining doesn't go away, make sure you have the correct fluid in it. Some take ATF and some take power steering fluid. It doesn't hurt it if you put the wrong fluid in, just change it soon. Mine whined like an old ford pickup steering until I put ATF in it.
Old 09-20-2005, 04:31 PM
Slant3's Avatar
84 Mutt
Cool. Thanks everybody for replies.I will go and test drive it now. I thought I screwed it up somehow. At first I couldn't even turn the wheel,- felt like the tires were glued.Then it got looser as I added more fluid.It was the sound of air release when I shut the car off that worried me.
Old 09-21-2005, 09:11 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
disagree with ATF. It will ruin a Ford or Chrysler pump pronto.
use STP or Lucas. Especially if it is a Ford pump.
Old 09-22-2005, 01:47 PM
New Member
Had PS fluid in my chrysler pump for about 2 months before someone told me it needs ATF. I flushed/changed the old fluid out and it hasn't whined or blinked since, and it doesn't leak either. It has to push around 36" tires too...
Old 09-23-2005, 12:26 AM
xntrik's Avatar
My gosh, I didnt realize we were using ps pumps from the dinosaur days, I thought they were at least the '80 types..... which use clear fluid.
Old 09-24-2005, 07:52 PM
New Member
Yah, well.... stuff from the dinosaur days outlast the crap today by a long shot. You have to agree with that
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 08:14 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 10:09 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
Bad Air Valve black66 Electrical 8 04-12-2005 01:44 PM
Help with a smog (air) pump 78 GMC Obrien78 Engine 5 07-25-2004 12:45 AM
