Air Checking 4L60E Servo - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2009, 06:13 PM
From the way i am reading this diagram if i apply air pressure to port 32 it should extend the servo and tighten band just like it does on port 25? Or am i reading it wrong. When i apply air a little hisses out #7 check ball port #28 servo pin does no move.
Old 09-17-2009, 08:43 PM
Crosley's Avatar
Wiki Edits: 1659
there is a hole in the pan rail area... put air pressure there, the servo pin should apply the band.
do this several times.
Old 09-17-2009, 11:47 PM
yeah but thats the exhaust and would not check the seal for 4th but would actuate the servo through 2nd
Old 09-18-2009, 06:26 AM
Crosley's Avatar
Wiki Edits: 1659
did you install the sealing ring for 4th gear dry ? Any oil on the servo pin?
I never air check the 4th gear section of the 2-4 servo and I never have a 'no 4th gear' problem.
Old 09-18-2009, 07:16 PM
oil on ring and i have a rig that i use that i fill with oil when applying pressure
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 06:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
98 4L60E billet servo blown68ssrs Transmission - Rearend 1 05-30-2004 04:46 PM
