Air checking forward drum assembly? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2011, 02:04 PM
6426yy's Avatar
TH350-Is air supposed to come out of the hole in the shaft and around the splines? Piston pumps up and holds fine. The directs and intermediates work fine. Can't remember if this is normal.
Thanks
Jesse
Old 10-09-2011, 06:01 PM
6426yy's Avatar
Put new rings in and solved my problem.
th350 air check the forward drum problems bodie filyaw Transmission - Rearend 4 02-17-2011 03:39 PM
4l80E Direct and Forward drum piston interchange blade42003 Transmission - Rearend 4 01-05-2011 09:25 PM
Air Testing Forward Clutch Assembly pukas84 Transmission - Rearend 5 11-24-2008 01:23 PM
Torrington Bearing between Direct and forward drum? 6426yy Transmission - Rearend 2 05-05-2008 02:28 PM
90/91 - 93 AOD Forward Clutch Drum ? macx Transmission - Rearend 0 05-18-2005 08:03 PM
