Air Cleaner Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2003, 12:47 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Question Air Cleaner Question
I want to change out my stock air cleaner, Since I seem to have a bit of heat under the hood will this give me problems with carberation? Should I look into fabricating come sort of cool air system? Or should I continue to use the stock unit with a "snorkel" to the front of the car. Also is there a good way of venting heat under a long hood?
Regards
Mark
Old 04-03-2003, 01:16 PM
Post
As far as switching the air cleaner,I don't know,but I think H.K. recomended louvering the inner wheel wells to alleviate heat problems and improve air flow thru the engine compartment.Maybe this will help?Bruce
Old 04-04-2003, 06:27 AM
Honorary Redneck
Post
I've got a bonnet scoop on my camaro, that helps cool down the engine bay a little
