Air cleaner vs. rain?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2008, 11:22 PM
Quick question. Say I were to cut a hole in my hood to poke my air cleaner out of there, would the rain affect this at all or should the filter keep it out?? The reason I ask is because I saw an old rod the other day all done up going down the highway in the pouring rain with the air filter right out of the hood and it didnt seem to suck in any of that rain. Would it matter which filter I went with or are they all a safe design meant to keep the rain out??
Old 06-02-2008, 02:27 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I wouldn't worry about a little rain. I often use a spray bottle to squirt liquid water in my carb while the engine is running to help break up upper cylinder carbon. I think it would take a pretty serious downpour to hydrolock the engine. I'd be more worried about the occasional splash you get from an oncoming car; you know, those ones that make you crap your pants when a semi tosses a huge puddle on you on the freeway?
Old 06-02-2008, 04:18 AM
79C10's Avatar
Viva la Migra!!
Just put a cool looking scoop over it..........
Old 06-02-2008, 06:18 PM
I had a Ford Torino with a functional hood scoop, and the rain protection wa simple.
The base of the air cleaner was standard size. In the center was a cover that only went to the edge of the filter, which left about a 3 inch gap all around for air to enter the filter. In the gap area there was a hole in the bottom of the housing, with a rubber drain hose.
On top of the air cleaner went another full diameter cover that sealed to the hood with a rubber gasket. This cover had a large hole in the center that matched the opening in the hood. Air came in through the scoop and down into the filter, and it had to make a couple of right angle turns. All the rain collected in the bottom of the large air cleaner housing (outside the filter) and was drained off from that area. The filter got damp sometimes, but never really wet.
On the factory Ford air cleaner they had a vacuum operated flapper under the hood scoop. This held the flapper closed at high vacuum (idle, etc.), and kept water out completely. This meant they needed to have an additional air inlet on the side of the air cleaner to let air in when the top flapper was held closed by high vacuum.
This web site has pictures of a similar system from a Mustang.
http://429mustangcougarinfo.50megs.c...ormation_2.htm
The pictures of the Cougar setup (near the bottom) and the "Air Cleaner Dimensions - for 71 429 Mustang ram air air cleaner" should give you something to work from.
Bruce
Old 06-02-2008, 06:30 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
It would not be the water getting sucked in the carb that I would be worried about.
Have you ever tried to breath through I wet wash cloth? How about putting a KaN washable air filter on while its still a bit wet? It won't let air pass while wet.
No air..NO fun.
Old 06-02-2008, 07:53 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hay Curtis,
When your bottle of liquid water runs out, do you
then use dehydrated water?
Rich
Old 06-02-2008, 08:55 PM
weirdbeard's Avatar
1976 Ranchero GT
Well water can be a liquid. solid or gas...
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 07:41 PM
What Size Air Cleaner for Mild 350 JohnTN Engine 1 12-11-2006 11:05 PM
Need help with air cleaner Dingman Engine 2 09-21-2006 10:43 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 06:52 PM
Air Cleaner Question Jag Daddy Engine 3 04-18-2003 06:35 PM
