Air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2008, 05:27 PM
raidmagic's Avatar
Last journal entry: Studebaker
Air compressor
So it's time I upgrade my compressor. I have some paint jobs coming up and mine just doesn't keep up. What is the min. CFM required to spray a car? I was looking at a unit at Home Depot the other day that has an air delivery 11.5/10.2 SCFM @ 40/90 PSI. That seems like it would be just right for what I want. Any thoughts? Here's a link to the compressor I am thinking about.
http://www.homedepot.com/webapp/wcs/...ctId=100083906
Old 04-27-2008, 07:49 PM
302 Z28's Avatar
That looks like a nice unit though the 11cfm@40psi is the upper limit for most HVLP spay guns.
Vince
Old 04-27-2008, 07:55 PM
It will work for a home shop but you will still run out of air with some tools especially when doing body work. If you plan to paint with it then it will handle a conventional paint gun just fine but most HVLP guns will be cutting it close and you will need to plan your spray pattern carefully to keep from running out of air on large panels.
Other tools that may or may not work so good.
Air file (board sander)- fair
impact wrench- excellent
air chisel-good
air grinder-fair to poor
DA sander-very poor
Blasting cabinet-fair to poor
sandblaster-fair to poor
conventional paint gun-excellent
HVLP paint gun-good to fair
air cutoff tool or die grinder- very poor
These ratings are strictly just my opinion so don't take it for anything more than that. While that outfit is a little light on CFM it is about what you will normally find in a home shop and with a bit of planing ahead when using the air hungry tools you should be able to do most anything you need with it, just that you may have to let it catch up a few times when using some of them.
Old 04-27-2008, 08:09 PM
raidmagic's Avatar
Thanks, that was just the info I was after. It is for a home shop so that is why I don't want to spend $1000 on one. I like my HVLP for final spraying but I could use my normal gun on big jobs. Planning out the panels is what I have to do now with my little compressor so I should do better with this one. Thanks again.
Old 04-27-2008, 08:10 PM
raidmagic's Avatar
Vince
What do you mean by upper limit? As in that's the least amount of air I can get by with? What kind of pressure should I have for an HVLP gun? Thanks
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
New Air Compressor blsnelling Garage - Tools 58 10-18-2007 09:36 PM
my first air compressor Guitar4God Garage - Tools 16 09-28-2007 07:14 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 06:24 PM
