Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air Compressor Choice Devilbiss vs Craftsman
  #17 (permalink)
Old 04-22-2011, 08:44 AM
oldred oldred is offline
Originally Posted by Jim Rockford
al also always go with the @90PSI if it has two cause that is what 90 % of all air tools run at. 140PSI really has no use on you as a homeowner.
This brings something else into the 60 vs 80 gallon equation that I have avoided because it is already confusing enough and besides the only way to make a meaningful comparison between two different tank sizes is if all else is equal, change the CFM input or pump type and there can be no real comparisons. A two stage 60 gallon tank compressor with 175 PSI is going to have a lot more air stored in it than a 60 gallon tank with only 125 PSI having the same effect as a bigger tank. This is all beside the point anyway but it is just another reason why looking at the size of the tank is useless unless it is a special use compressor with an extreme tank volume one way or the other. An example of that was our most popular rig when building service trucks, a 32 CFM compressor with a 30 gallon tank. The small tank was used to save valuable space and the operator depended on CFM to make the thing useful.
