air compressor drain plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2009, 08:53 PM
Does anyone know the size of the drain fitting that is located on the bottom of the tank of a Kobalt K7060HFV compressor. I want to replace the fitting with a new fitting that is easier to turn, one like on a radiator.
Another question, can i simply turn the center fitting out and replace it with the wing nut type center fitting? Or do I need get a wrench and replace the entire fitting? I can't find any info on the fitting size, I hope it is a 1/4 - 18 NPT threads. Thanks for any input, Happy Thanksgiving
Old 11-22-2009, 06:52 AM
Last journal entry: 50 Ply wagon
Most all the fittings on the bottom of any compressor can be replaced. I replaced mine with a petcock style from a radiator. I would just remove it and check out the thread size, should be an easy fix. You won't know anything till you take the present plug out anyway.
Old 11-22-2009, 07:59 AM
81 Vette
I am a idustrial pipe fitter and can 100% tell you that all fittings in air tanks are pipe treads.
Old 11-23-2009, 07:33 PM
bondo's Avatar
Ayuh,... The odds are about 99% that the hole in the tank is threaded 1/4" pipe...
You have to replace the Whole fitting...
I replaced mine with a 1/4" "T" fitting, close nippled to the tank, with a ball-valve on 1 side,+ a pull-cable drain off a Big Truck on the other side...
With the other end of the cable at the top of the unit,... No need to bend over anymore,...
If it Really needs drainin',... 1/4 turn of the valve,+ it's free flowin'...
Old 11-23-2009, 08:11 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You can go to Lowes or home Depot or any place like that and buy a compressor drain petcock. They are a pretty standard size.
Old 11-24-2009, 04:40 PM
Thanks for all the replys, i was hoping it was a 1/4" fitting, that about all i could find. My tank drain isn't real difficult to get to, but getting the right fitting up front would make the swap easier. Thanks again
Old 11-25-2009, 01:08 AM
This is what I did with mine.....
Old 11-25-2009, 05:45 AM
weirdbeard's Avatar
1976 Ranchero GT
That sure makes things easy.
Old 11-25-2009, 06:15 AM
deadbodyman's Avatar
Wiki Edits: 11
I like that idea.....
Old 11-25-2009, 07:28 AM
It is a good idea but don't get carried away with the length, keep it well back under the tank, because being down near the floor like that they can easily be broken off that's the reason they don't come that way from the factory.
Mikewb, you need to turn that thing 180 deg because the way it is it will be easily bumped if you move the compressor around but if you turn it the other way it would be pointing up out of the way when the tank is tilted back, still fairly easy to break off on a portable compressor however but not nearly as likely.
Old 11-25-2009, 10:23 AM
oldred:
I already checked that out already, it doesnt touch the ground even when tilted way back I guess thats where the big wheels come in handy
Old 11-25-2009, 09:21 PM
I was going to replace the drain tomorrow but it looks like I have changed my mind on how to do it. I will now wait until Friday and go to HD and get a few fittings and a ball valve. The less i have to bend over and drain the air compressor the more bends i will have left to work on my ole truck...thanks again
Old 11-25-2009, 10:17 PM
How about this?
http://www.harborfreight.com/cpi/cta...emnumber=46960
Old 11-26-2009, 06:03 AM
Wiki Edits: 11
Those auto drains are great for regular work and that price is great.but I dont care to much for them in the paint shop...If they fail it'll cost you dearly ...plus I'm used to draining the tank as part of the procedure ....something everyone should get used too every day.That cable and ballcock is a great idea and with one more improvement its perfect.....A hose and something to catch the water....My compressor dumps about a half gal of water on the floor which is a pain when you turn the drain off ...Thanks for the good ideas...Have a great thanksgiving...
Old 11-26-2009, 10:00 AM
I have a HDA70600AV filter from HD, although I havn't tried to clean it out yet. I have heard it isn't very easy to work with. i didnt do much research before i bought it, my fault. I do not do much painting, mostly priming and using air tools. Any tips on cleaning the filter i have? I am concerned I will get it apart and it will not go back together and then I will be without air. I will take a look at the drain from HF and see if i have room to use it. thanks
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 06:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Need to plug air injection holes in my headers. What size bolts? Porchev Engine 7 01-27-2006 01:36 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
