Air Compressor / Dry Air - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2013, 07:48 PM
Mac88's Avatar
"Drive It Until It Breaks"
I was looking through the forum and found an old post that addressed the problem I needed help with, but did'nt fully answer my question. I have a regular two car garage and not a large shop. I'm trying to figure a to get 50ft. of pipe so I can run my air through a dryer but because of the size of my garage, it's kind of difficult. I read an article where someone was saying they built a copper cooling board with 50ft of copper piping. That sounds like it would work, but my question is exactly how could this board be built without having low spots that would hold water? If anyone has pictures, it would be greatly appreciated.
Old 06-15-2013, 09:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I'm not sure if you are talking about my "cooling board" or not, but I built mine based on another member's idea here on HR.
My airline is fairly short ... just runs the length of the wall on one side of my 24' x 34' garage. The relatively dry supply line is mounted up high on the wall, and has vertical drops to the outlets. Note the union at the termination of the overhead supply line, as well as the spare lengths of copper tubing on top of my cabinets ... just in case I decide to plumb the rest of my shop some day.
These outlets are mounted on tees, with a length of tubing below them. Each one has a drain valve to remove accumulated moisture. I have been more than happy with this setup, as moisture rarely even makes it as far as the water trap.
Old 06-16-2013, 06:44 AM
Mac88's Avatar
Re
66GMC,
Thanks for the response. I believe this is what I was looking at and I think it would be the answer to my space problem. You dont have any problems with condesation collecting in the board? This looks like exactly what I need, thanks. I just did'nt want black pipe running all over the place.
Old 06-16-2013, 07:06 AM
Wiki Edits: 27
propane bottle
Someone here on Hotrodders posted a desicant type dryer made from a propane bottle and filled with kitty litter. I welded up the fittings on a medium RV bottle and have the kitty litter but didn't get it finished before we came North for the summer Farm work. I have one of the clear plastic canisters to run after the bottle that changes color when it gets saturated with moinsure. Moisture in the air lines did $ 100 damage to the plasma cutter tips in 2 seconds. I have been thinking about looking at a small refrigerant dryer if I get a progect far enough along to Paint with something beside primer. When I was south a few years ago I signed up for a "Paint your car" college class but it was cancelled. Most class fees were cheaper that the overhead to heat and run your own shop.
Old 06-16-2013, 07:12 AM
Wiki Edits: 27
inverted U
Air lines are recommendet to slope down hill to an end of line drain and have the take offs plumbed in an inverted U, first go up out of the main line, then down to the hose connection. I have an auto drain valve on my tank but it still doesn't get enough moisture out.
Old 06-16-2013, 08:48 AM
Mac88's Avatar
Re
I'm just looking for a simple system to keep moisture from my air tools and blaster. I'm a Deputy Sheriff full time and I only work on my Mustang when I have a little free time, so I would prefer not to put alot of money in top notch, professional grade systems. I saw a refrigerated dryer at HF for $300. I may end up going that route. For the amount of work I do, I really dont need it, but I like things to work when I need them. I like the idea of the cooling board, but I think as far as cost, after buying all the materials to build it, I could probably go with the refrigerated dryer and pay about the same. Thanks for the response.
Old 06-16-2013, 10:06 PM
66GMC's Avatar
No, I don't.
The 4 ball valves are normally closed, which forces the air up and down those 3 or 4 loops.
Moisture drops out of each of those loops due to cooling and gravity, then collects in the tube directly above each of those valves. Opening those valves one at a time blows off any accumulation, which exits through the horizontal "manifold" pipe at the bottom.
1.)I drain the compressor tank, which is where the vast majority of water collects.
2.) I blow off each of the 4 ball valves on the cooling tower. The amount of condensate diminishes (as I would expect) as I progress.
3.) I check the filter/drier, and rarely find that much if any moisture has made it that far.
4.) Before I plug in any air tool, I crack the ball valve below the outlet just to be 100% sure that I'm using dry air.
The caveat here is that this is just my home garage/workshop, and the most air-usage-intensive project to date has been a bit of sandblasting with a small hand-held spot blaster and spraying some paint with a siphon gun.
Other than that ... filling tires and using the blow-gun is about the extent of my weekly or monthly usage. That 18.5 CFM compressor is overkill, but I got it cheap!
I do plan on using it for a much bigger job, hopefully soon. The plan is to get my hands on a 20-gal pressurized sandblaster and re-blast my pickup cab. I have done this before using a nearly identical compressor. The compressor ran pretty much non-stop, but it did seem to keep up. That will be a good test, I think, of how well this "cooling tower" really works.
Old 06-16-2013, 11:19 PM
Mac88's Avatar
66GMC,
Thanks, I'm going to run down to run down to Lowes tomorrow and try to get the materials to build one of these. I think I'm going to try and use gator bites or some type of compression fittings. I never have alot of luck with soldering. It may cost a little more but I think it's worth it as opposed to doing all that work just to find leaks.
I'm only working in a small garage and I only do small blasting jobs too, so this will be perfect. Thanks again.
Old 06-17-2013, 01:49 AM
Wiki Edits: 31
Make sure the gator bites are rated for that kind of pressure.. Gator bites are about the greatest invention ever for quick fixes to water lines, but I have never used them for air pressure
Old 06-17-2013, 07:08 AM
Last journal entry: Still running strong
I used 3/4 steel pipe that I bought at Lowes, they can cut an thread the ends for you, and have all the fittings also. My compressor is on one side of my garage door, ran the pipe up the side then over an down to the other side where the filter is.The pipe is slanted towards the compressor above the garage door so any water runs back to there. This cures any water issues but theirs going to be some water vapor.
Old 06-17-2013, 03:12 PM
66GMC's Avatar
Ditto!
Soldering copper pipe really isn't all that hard if you have:
1.) A good propane torch
2.) A (approx) 6" square peice of scrap tin (perhaps with some sort of insulated handle oe even vise grips) to sheild heat from the work area behind the pipe.
3.) Soldering flux paste
4.) some emery tape abrasive roll (180 - 240 grit?)
5.) Acid core solder for plumbing, NOT rosin core.
Bob Vila's instructions
In addition to his instructions:
I like do a trial fit, and use a sharpie marker to make sure the rotation is lined up properly. I also try to plan for the need to have swivel joints or unions wherever disassembly might be nessecary (i.e. ball valves, filters, hose reels etc with threaded connections) for service.
Speaking of threaded fittings ... I'm a big fan of the brass ones. Make sure that you are buying "sweat-on" fittings for copper and not PEX.
PlumbingSupply.com
I used pre-crimped truck air-brake hoses to connect the cooling tower to the compressor and the filter for both vibration and flexibility reasons. Few things are more irritating to me than vibration being passed down the entire length of my airline.
You can do it!
Here's what I used for sweat-on drain valves.
Old 06-17-2013, 05:36 PM
Wiki Edits: 27
sheet rock guard
When the flame could ignite something I like to use a scrap piece of sheetrock, and a spray bottle of water, Dampen the side towards the flame.
Home A/C a-coil for a air compressor air dryer? kevs79 Garage - Tools 14 01-07-2013 12:52 PM
Hot air from air compressor intake Mach1460 Garage - Tools 9 07-09-2012 12:43 PM
Show off your homeade/ancient air compressor/air supply system! ChevelleSS_LS6 Garage - Tools 2 08-07-2005 07:39 PM
air compressor clean air intake? montea Garage - Tools 18 09-22-2004 06:53 AM
