Air compressor for the garage ?????
I have to replace my Sears Crapsman air compressor now I'm trying to decide between a Husky or Campbell Hausfeld. would like to here some feed back on these if you have any looking at the 60-80 gal sizes
iam planning on getting the campbell from tractor supply for 439.00 . it is also to replace a small craftsman. that does every i want just for not very long.
With something that large, go for an oil cooled one, with as many USA/Canada made components as possible. You could keep your old craftsman tank for a larger capacity, but that still wont' offset a small pump over a long use of time.
Both Husky and Campbell are about the same quality and will work fine for the typical hobby garage use. As the other posters mentioned, their are a few basic specs to look for:
Oil vs oil-less pump: Go with a compressor that uses oil. These compressors are quieter and they will last longer saving you money in the long run. CFM: Determine the CFM requirements of the air tools you have or want to get. Get a compressor that has 50% more CFM capacity than your largest air tool because both the compressor and air tool manufacturers fib a little with their figures. Horsepower: Ignore any HP ratings. HP figures have not matched true HP for years and are so unreliable they cannot be used as a selection criteria. Once you get your new compressor home make sure you change the oil per the manufacturers recommendation and drain the tank regularly and you will have you compressor a long time
| Recent Garage - Tools posts with photos |
| Air Compressor Types- What do you have? | ChevelleSS_LS6 | Garage - Tools | 129 | 08-23-2009 09:11 AM |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| Piping air line from basement into the garage - help needed | mikeweb | Garage - Tools | 24 | 07-09-2007 09:52 AM |
| respirators and supplied air | robs ss | Body - Exterior | 12 | 08-30-2006 07:44 PM |
| Bad Air Valve | black66 | Electrical | 8 | 04-12-2005 12:44 PM |
