air compressor oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2006, 02:15 PM
air compressor oil
For what its worth, I just came back from my local xxxxx xxxxx store in Manitowoc wi.
I bought a 7 horse two stage compressor from them one year ago almost to the day, I went to pickup there xxxxxxx brand oil, and it says synthetic on it, different part number then what they had before.
The people in the deparment were not sure if it was okay, thought it was.
So I made three calls to xxxxxx xxxxx to enlighten them.
Then I called the store to inform them whats going on.
So for us with compressors, my manual says after 300 hours its okay to use synthetic compressor oil.
They quit stocking regular air compressor oil. Yet there selling new compressors that need the other oil to break them in
So there is not a lot of thought process going on between the manf and who sells there products.
So read your manuals carefully when you go to buy your oil, just a little heads up.
Rob
"There are questions to be answered, and answers to be questioned"
Chassis, Body Jig, Trunk Pan Pics.
http://webpages.charter.net/2manitowoc
Paint
Old 11-29-2006, 02:38 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
"What we've got here is failure to
communicate.
Some men you just can't reach...."
-Guns N' Roses
Old 11-29-2006, 02:51 PM
jor jor is offline
I have an old SnapOn compressor. The factory documentation calls for 10wt oil. I couldn't find any straight 10 wt anywhere and was told that everyone now uses 30 wt compressor oil (non -detergent so it won't foam) Anyhow, I ended up going to synthetic and all seems to be well.
jor
Old 11-29-2006, 03:32 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Air Compressor oil is non-detergent. The reason being...a lot of air compressors the crank dips down into the oil sump...this will cause foaming if the oil is detergent type. The resulting foam ( air bubbles) keeps the bearings from having a uniform coating of oil on them and could cause bearing failure. I use 30 wt. Non detergent oil in my 5 HP Ingersall-Rand compressor.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 06:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
