Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air compressor oils
Old 06-29-2007, 07:22 PM
SteveU SteveU is offline
The only issue I had last winter during the cold spell was I had to point the salamander at the auto drain for a few minuites to get it to blow off. After that I blew it off when I was done in the shop & turned the air valve off & shut off the power so that it wouldn't make more water. I really believe that synthetic oil is the way to go unless your compressor is in a place that is always heated & even then I would use it because of the better protection it gives. Everything I have has synthetic in it mowers, cars, bike, compressor. Once winter hits I will take another reading on the current draw & see how much it changes from warm weather, definitly don't want to burn anything up. Never thought about that happening Oldred, thanks for the heads up.
