Air compressor piping/hose from tank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2007, 05:27 PM
What do you all use to connect the tank to your air line setup? I currently have a 3/8" flexible line to a regulator/filter. I'm starting to plumb in hard air lines to some various spots in my workshop that are 1/2" pipe. What should I use to connect to the 1/2" pipe? Is it ok to come straigt out of the tank w/ the hard lines....I would think that vibration wouldn't be a good thing! I can't find 1/2" flexible lines. Any ideas are appreciated!
Thanks - Drew
Old 01-09-2007, 05:35 PM
Wiki Edits: 31
Thanks - Drew
I have a short length of 3/8" reinforced fuel line, connecting the compressor to the hard lines., but I only run 120 PSI. runs thru a quick connect and a lot of water condenses right there in the hose, works pretty good. cool thing is, it expands just a little, increasing flow and volume
Old 01-09-2007, 05:52 PM
I wasn't sure if it was the norm to put a smaller size flexible line(3/8") connecting to larger size piping. I would think it may restrict air flow a little. Do they not make 1/2" flexible lines??
Old 01-09-2007, 05:54 PM
Wiki Edits: 31
yes they do. I only used 3/8" because the fittings on the compressor are 1/4", I went 1 size up.
Old 01-09-2007, 06:04 PM
I used a 3/4" hydraulic line I bought from Tractor Supply and it works just fine. I think somebody here recommended them so I tried it.
Danny
Old 01-09-2007, 06:43 PM
Kampr is right you just can't beat hydraulic hose it's flexible, is rated for many times more pressure than it will will ever see on a compressor, easy to find with pipe threaded ends, available in any length and size, will outlast your compressor and is fairly inexpensive as long as you just get the standard pressure ratings.
Make sure the hose is at least as big as the line and one size larger would be even better. Also when you get this all set up be sure and move that regulator/filter away from the tank as far as you can since it will do little to remove the water from the lines if it is near the tank.
Old 01-09-2007, 07:35 PM
thanks..I'll give the hydraulic line a shot! I sure do spend lots of time building a garage....wish I could use the stuff more!!!
Old 01-10-2007, 05:03 PM
cab cab is offline
As others have stated I ordered a pre-made short hydraulic hose along with two extra SWIVEL fittings (these are key) from Northern tool - mine was 3/4" since I am using 3/4" copper pipe. Worked like a champ.
Old 01-11-2007, 09:47 AM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
Yup hydraulic hose here also.
Old 01-11-2007, 02:22 PM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
Funny thing, I went to a hydrolic shop to get a hose made up and they refused. Telling me that the inside of the hose will over time show dry rot. Wether this is true or not I havent a clue.
I ended up getting one made at a local Auklands Granger supplier.
Old 01-11-2007, 03:54 PM
I can show you some that have been in use for nearly thirty years. I suppose most anything will fail after enough time but a new hydraulic hose will easily outlast most compressors.
Old 01-11-2007, 08:22 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
it's rubber! of course after 30 years it'll dry rot. Look at old tires, especially ones exposed to the elements. Replace the hydraulic hose every 15 years or so and you'll be safe from "internal dry rot" .
I think it'd start on the outside first from UV rays, dirt, and crud like that.
-Matt
Old 01-12-2007, 07:20 AM
I use an 8' long piece of 1" rubber hose that I had made up at a place that also makes hydraulic hoses for 35.00. I will ask what the same size hydraulic hose would cost one of these times. This is more flexible than hydraulic but in the 1" size it's still not very flexible.
Old 01-12-2007, 07:43 AM
I bought my hydraulic hose at Tractor Supply and while I don't remember what I gave for it I don't think it was anywhere close to $35.00. You might try somebody that has them already made up. It might be cheaper.
You need something flexible coming out of a compressor. Anything Flexible would probably deteriorate over time. I'm not saying the hydraulic hose is the best because I don't know but I bet it would be hard to find anything better.
Danny
Old 01-12-2007, 08:06 AM
jor jor is offline
Here's some photos of mine. I had it made up at a Hose and Rubber place. It cost me $25 and the components are:
* 3/4" hose
* MPT fitting
* MPT swivel fitting
jor
Name:	Air Connections - 1.jpg
ID:	17644   Click image for larger version
Name:	Air Connections - 3.jpg
ID:	17645   Click image for larger version
Name:	Air Connections - 4.jpg
ID:	17646   Click image for larger version
Name:	And yet more air - 9.jpg
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 129 08-23-2009 09:11 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
Kustomsledd fuel tank, how I made it... DrChop General Rodding Tech 4 10-28-2003 12:47 PM
