Air Compressor Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 11:55 PM
I am having some trouble judging if an air compressor will meet my painting needs. I'm only going to be painting a motorcycle gas tank (Hotrodders like bikes too, right?). I plan on using an Astro evo spry gun, the rating is 7.8 CFM @ 40 psi. The compressor I plan on using has the brand name Air America, when I looked it up it brought up Devilbiss parts. The compressor is a 4HP 12 Gallon (Model Number: FB412-1), rated at 7.8 CFM @ 40 psi. Even though the tank is only 12 gallon, will running the compressor constantly make this setup work? I understand that this compressor has a 50% duty cycle, but painting a gas tank shouldn't take too long. Thanks for your time.
Old 07-13-2008, 12:02 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You should buy the biggest compressor you can afford. They are so handy. That said.. You should be fine just panting your tank with that. It does not take much for cycle parts.
Old 07-13-2008, 12:13 AM
Thanks for the reply. I already have this compressor lying around and can't justify buying a quality one for painting at the moment. Otherwise I would just get one that could do the job right. Thanks again.
Old 07-13-2008, 07:09 AM
adtkart@aol.com
The size of the tank has no bearing on the capabilities of the compressor. That should do fine for that gas tank. For painting a whole car, you would probebly have problems.
Aaron
Old 07-13-2008, 10:05 PM
Thanks for the help.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 10:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 07:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 03:18 PM
