Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air compressor for sandblaster
Old 02-13-2013, 02:04 PM
Northstar T's Avatar
Northstar T Northstar T is offline
Gone sailing
Originally Posted by suspect View Post
This is the compressor I'm running. Cambell Hausfield, 60gal, 240v, 15amp, 1 phase, oil cooled, 135 psi, 3.2 hp, 11.5 scfm @ 40psi, 10.2 @ 90 psi. I paid $530 including tax last summer (at Steve's's like a Harbor Freight). This comp is more than enough for what I do, it never runs out of air when I'm using my die grinders, DA's, or cut off wheels.
Other dude is right though, sandblasting does take a whole lot of air. Sorry I can't give you feed back on if mine holds up to that. You may need alot more than 135 max psi.
I have this exact same compressor. It's been great for the 6-8 years I've owned it, but marginal volume for bigger sand blast jobs. I use mine with a small/medium size cabinet blaster once in a wile, but sometimes have to wait for it to catch up. for just blasting small parts it's fine however. works fine for painting also.
good bang for the buck IMO.
