Air compressor for sandblaster
I have a question on what type of air compressor to purchase for a large blast cabinet. Its big enough to put a motorcycle frame in it. The cabinet is used but one of the old ones. I'm not sure what size nozzle it has. It needs some stuff done to it to get it running.
Here's some of the things I had in mine. 60 to 80 gal The garage is 200 amps Enough to operate any tool without bogging down and waiting for air to build back up. Not sure how much HP I will need. Stationary $500-800 I may have to spend more. Any help is appreciated Thanks |
One more thing. Single stage or 2 stage? What's the difference and what's the benifit over the other?
I dont know exactly, but it needs to be BIG.....Sandblasting takes a ton of air
Ontario Rodders |
good bang for the buck IMO. Russ |
I'd recommend a two stage, 7.5 hp, 80 gallon with atleast 15 CFM at 90. Bigger would be better if you plan to blast regularly, but that should get you by. A compressor running all the time is not only bad for the motor and compressor, but it also creates heat which will in turn create condensation, which will be bad, very bad with a blaster set up. With blaster, you need volume not pressure, I never use over 100 PSI blasting on frames and thicker metal and usually around 85-90 on sheet metal. Of course what size nozzle, air line, filters, water traps, whats being blasted, and media used plays a big part in how much pressure you need too. Maybe you could check the other shops in your area and see if they will share information on their set up.
Kelly |
CFM Required
I like Carolinacustoms never use very high pressure to blast with. I found this site that has a cfm chart for a given psi and orfice size but i couldnt copy and paste it into this forum(probably could have but im a mechanic not a computer geek) here is a link you can follow,
Rod Air Flow Through Orifices |
| Recent Garage - Tools posts with photos |
| air compressor&sandblaster question | cutthroatkid | Garage - Tools | 14 | 02-11-2013 09:19 AM |
| Home A/C a-coil for a air compressor air dryer? | kevs79 | Garage - Tools | 14 | 01-07-2013 12:52 PM |
| Air conditioning---Vintage Air with a R-4 compressor | Bryan59EC | General Rodding Tech | 1 | 01-02-2010 03:34 PM |
| Sandblaster compressor used for painting? | Siggy_Freud | Body - Exterior | 8 | 10-04-2006 10:03 PM |
| Show off your homeade/ancient air compressor/air supply system! | ChevelleSS_LS6 | Garage - Tools | 2 | 08-07-2005 07:39 PM |
