Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air compressor&sandblaster question
Old 02-11-2013, 10:19 AM
Old Fool's Avatar
Old Fool Old Fool is offline
Originally Posted by mc73DD189 View Post
I should have read this thread before I started mine
Good info! Couple of questions
Does it matter what size blast cabinet you use and if my garage is running on 200 amps, I shouldn't have to change any outlets, correct?
200 amps is the size of the main breaker, the total load the panel will handle.
It has no direct relationship to your outlets.
You need a circuit that is wired with the proper size receptacle, wire and breaker for the load you are going to connect to it .
