air compressor for shooting paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2014, 02:35 PM
I am getting ready to paint my car and need to know what size air compressor in terms of CFM and pressure does it take to shoot paint?
Old 03-14-2014, 05:29 PM
You need to size the gun to the job then the compressor to the gun. This is where a home paint job gets expensive.
You'll have to shop and shop hard looking at specifications. They like to sell compressors by horsepower. This counts but is a huge range of efficiencies between what the motor is rated at in power and what the compressor delivers in pressure and CFM. CFM and pressure is what counts not motor power. In general as pressure goes down in the specification the available CFM goes up.
Spary guns vary all over as well. One usually assumes that HVLP guns use less air CFM and pressure than the older syphon guns, this isn't exact in all cases. The bottom end DeVilbis Starting Line model needs 13 CFM at 30 PSI. step up a level in quality and the gun needs about 13 CFM at 20 PSI.
Very inexpensive guns that look the same as the DeVilibus can use 4 to 7 CFM at 30 to 50 psi, these are fine but deliver a smaller pattern. however you've got to watch out there are some inexpensive guns that chew up a lot of CFM and pressure while still advertised as HVLP guns, imagine 17 CFM at 50 to 70 PSI in one example.
The compressor needs to be able to continously support the pressure and CFM requirement without thermally cutting out. These also need wiring to support their cycle, voltage and amperage requirements. 110 VAC motors will be smaller and power hungry, 220-240 will be a bit easier on the amperage which sizes the wire and breakers. Home and most shops ony use single phase. Three phase is very expensive to have wired as are converters to make 3 phase. Typically 2 horsepower can support less than 10 CFM and less than 50 PSI for painting with about 5 horsepower to support 13-14 CFM at about 40 PSI. This is just general, you've got to shop to the required numbers of what the gun needs. As with most everything a larger compressor than needed is easier to live with than too small for the job.
Bogie
Old 03-15-2014, 07:06 PM
volume is CFM. HVLP=high volume, low pressure. So if one knows what they're doing, they should assume an HVLP gun will consume lots of air volume, which they do.
So to answer the original poster's question, you'll need 13-15 CFM minimum. My compressor is 3.7 hp, 60 gallon, at that CFM range, and I'd say it's the minimum you want for spraying an entire car with HVLP. Which I have done. I use the large 3/8" fittings from compressor to gun. My airflow never goes through a 1/4" fitting, wall regulator is ran wide open, with the gun regulator set to anywhere between 18-30 psi, ultimately depending on what I'm spraying. Adjust your air pressure to get it to spray how you need it, not what the gun tells you.
Old 03-15-2014, 07:40 PM
CraigK's Avatar
Last journal entry: For a change of pace
Lizer is saying,
Buy a real air hose. No dollar store coiler hoses to restrict the air flow.
Anybody own or have info for a 5hp 18.5 80gallon blue Excel Compressor air compressor snapped finger Garage - Tools 0 03-24-2013 11:33 PM
Compressor size for shooting and using a DA Jimbo17 Body - Exterior 8 08-22-2012 08:16 AM
Trouble shooting Van Air compressed air dryer awert Garage - Tools 5 02-16-2009 02:46 PM
Trouble shooting Vintage Air for the Novice wretched ratchet General Rodding Tech 8 05-07-2008 07:27 AM
Show off your homeade/ancient air compressor/air supply system! ChevelleSS_LS6 Garage - Tools 2 08-07-2005 07:39 PM
