Air compressor shop lines - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-24-2012, 10:27 AM
K72Nova's Avatar
Sounds like I'll have to give Quincy a call and see if there is a way for me to hook up a 3/4 outlet.
  #17 (permalink)
Old 10-24-2012, 03:58 PM
Last journal entry: was hoping for better than this
Originally Posted by delawarebill View Post
it really makes no sense to run a larger line then the fitting on the compressor is. if u look for more storage of air then a lg line is ok.. IF u want flow... then make sure the fitting from the compressor is the largest it will take. the smallest part of that line is an "orfice" and u can not flow more air then that part will allow. and thats the ID of any part on that line.
my outlet at tank is 1"
and I'm running 1" all the way to the outlets for the hose..
the dryer is only on one outlet, for painting..
water seperating filters at the other 3 ..
  #18 (permalink)
Old 10-25-2012, 07:03 AM
Too Many Projects's Avatar
"Junk Collector"
Last journal entry: Headliner
I would be very surprised if a compressor with that capacity had only a 1/2" outlet. The pic appears to have a reducer bushing in a much larger bung. Looks like a nice compressor. I have the IR match to it. It runs most of the time to keep up with my blast cabinet and runs full time with my pressure pot.
The copper will transfer heat faster than pipe. I have 50' of black iron threaded across my ceiling for cooling with 3 drops to drain off water. I had read the galvanized coating was thin inside the pipe and people had problems with it flaking off and clogging fittings so I used the black. It's been in there 8 years and no rust issues...
If the drain valve is still under the tank, buy a street elbow and run it out to daylight. MUCH easier to turn the handle out where you can get at it.
The Following User Says Thank You to Too Many Projects For This Useful Post:
K72Nova (10-25-2012)
  #19 (permalink)
Old 10-25-2012, 12:49 PM
K72Nova's Avatar
I'll have to run out to the garage tonight and check out the outlet, I’m hoping you’re right about the reducer, I've heard the same thing about galvanized. The drain valve sticks out just enough for it to not be a problem; I’ve heard of other people having issues with it so I’m wondering if it was something that were corrected through the years. Thanks for the input
  #20 (permalink)
Old 10-25-2012, 04:40 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Originally Posted by rdupree View Post
If you are going to use iron pipe, be sure to use galvanized pipe. At a former employer, they installed a new air system, all of it in black iron pipe. Inside of about 6 months, the inside of the pipe was already rusting and generating lots of rust that clogged the insides of air tools, etc.
Galvanized pipe has issues also. The galvanize will start to flake off, check out this article by Exair, very informative: Compressed Air Piping
  #21 (permalink)
Old 10-27-2012, 06:43 PM
Made me laugh when I read "vic" connections are easy. Well while it is true, I do not think many will have a grooving machine to groove the pipe before the easy installation of the actual "vic" coupling.
I have ran miles of grooved pipe, 2" to 12", copper,black iron, galv,stainless, and plastic. It is fast and easy once you have thousands of dollars of equipment purchased, lol.
Personally I like type L copper for air lines, fast simple, one time install, and easy to modify when you need another connection at a later date.
Parts for GM Goodwrench shop air compressor model 5005 mike 96 ws6 Garage - Tools 5 10-24-2011 07:12 AM
Sealing Shop air lines aminga Garage - Tools 11 01-15-2009 07:50 AM
more compressor lines FiveFeezy Garage - Tools 8 01-03-2008 01:32 PM
paint booth, supplied air, ventilation, air lines robs ss Body - Exterior 1 12-04-2005 03:27 AM
Show off your homeade/ancient air compressor/air supply system! ChevelleSS_LS6 Garage - Tools 2 08-07-2005 07:39 PM
