Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air Compressor Silencer
Old 03-15-2009, 10:47 PM
ChevelleSS_LS6's Avatar
ChevelleSS_LS6 ChevelleSS_LS6 is offline
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
I'd make a 'doghouse' for a compressor if I had a shop... basically a small concrete pad connected to the building. On the concrete a rubber mat would minimize any vibes and resulting noise, and the 'garage' side would be sealed as the roof would be too.
At least the 'away from garage' side would be assembled with louvered slats (think siding with that's angled out so it lets air circulate but keeps air out) line this with screen on the inside to keep bugs out. Perhaps all three non garage facing sides would be like this if it's in arizona or another hot place.
It'd be setup as Compressor/tank with a shutoff valve, hard line through insulated wall and there another shutoff valve, drier/filter and psi gauge, etc.
