Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air Compressor Unloader Valve line keeps popping out...
Old 12-01-2007, 10:05 AM
oldred oldred is offline
Just scrap the line and go down to the hardware store and get a new plastic line with some new brass ferrules and make sure that you get the little brass insert that goes INSIDE the line to support it when the ferrule is tightened. It sounds like the insert is missing and if that is the case even if the ferrule crimps properly on a plastic line it will simply collapse and slip out no matter how tight you get it if that insert is missing. The whole outfit will only cost about 4 or 5 bucks, maybe less.
