Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air Compressor Unloader Valve line keeps popping out...
Old 12-01-2007, 04:21 PM
oldred oldred is offline
When you say the insert is not completely round are talking about the ferrule or the insert that goes INSIDE the line? You should have a compression nut that screws to the fitting and that the tube goes through, a brass ferrule that the tube also goes through and is crimped by the the nut and a brass insert the size of the ID of the tube that slips INSIDE the tube to support it when the ferrule is crimped. Do you have all three pieces?
