Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air Compressor Unloader Valve line keeps popping out...
Old 12-03-2007, 08:02 AM
Shakabrah Shakabrah is offline
Originally Posted by oldred
When you say the insert is not completely round are talking about the ferrule or the insert that goes INSIDE the line? You should have a compression nut that screws to the fitting and that the tube goes through, a brass ferrule that the tube also goes through and is crimped by the the nut and a brass insert the size of the ID of the tube that slips INSIDE the tube to support it when the ferrule is crimped. Do you have all three pieces?
I have:
1)the plastic line (small) 1/8" dia???
2) it goes thru a small brass fitting that has threads on it
3) after that a small brass tapered fitting goes on the tip of the line and the very tip - it won't go past it. This is what I superglued onto the tip. So far it has worked.
4) then all I insert the line and (tip) into the valve line assemble and tighten #2 into it.
Before superglue just the plastic line would pop out and I would have to unscrew both brass fittings and start over.
