air compressor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2010, 11:43 AM
I just purchased an air compressor that is 240v / 60 hz / 9 A ( load ) single phase 2 capacitor run and start, 15 A overload reset , that has a 3 wire cord wired to it minus the plug. I have several outlets in my garage that are round 3 prong and says 125 / 250v / 50 Amp on it . I am sure they are there for use of a welder and I am am sure they are 240. The breaker that says " air compressor " that I think runs these outlets is a double pole 60 Amp . How can I be sure the power is not wired for 3 phase and can I simply purchase a plug to fit the outlets an be good to go , or is there going to be a problem ? Any help would be great . The picture is the outlet that I need to match a plug to . Thank you ! Tim.
Old 04-07-2010, 11:48 AM
302 Z28's Avatar
Yes, you can purchase a suitable plug that plugs into your 50 amp receptacle and use that. The 50 amp breaker feeding that receptacle protects only the wire and receptacle not what is plugged into it. You can always plug in an electric device with lesser electrical requirements into a greater capacity service.
Vince
Old 04-07-2010, 12:01 PM
Thank you very much for the help Vince !
Old 04-07-2010, 01:13 PM
302 Z28's Avatar
Glad to be of help.
Vince
Old 04-07-2010, 07:16 PM
Old Fool's Avatar
"3 prong 125 / 250v / 50 Amp "
I have no idea what you have, either the outlet is 120 or it is 240 it cannot be both.
before plugging anything into it I would confirm its voltage with a meter.
Old 04-07-2010, 08:14 PM
302 Z28's Avatar
There is a 50A 125/250V Grounding receptacle NEMA 14-50 3 pole-4 wire
Vince
Old 04-07-2010, 11:19 PM
Wiki Edits: 27
4 wire plug
the 4 wire plug uses green wire -grounded... white neutral ...black and red for hot.... black to red is 250,... black or red to white is 125.... the 125 (sometimes called 110 or 120) is usually used for the control circuit, timer on a dryer or stove, lites etc. house hold electrical is single plase.... 3 phase is for some commercial machinery. more efficient and usually produces more power. technically you should not connect to the 50 amp outlet since the power cord is not the correct size. Most household use compressors that size use a cord plug that looks similar to a regular household plug except the straight blades point toward each other and are rated for 20 amps. If you have a dedicated circuit you could change the breaker and receceptical to be technically correct but i have bought used equipmet that had 30. or 50 amp plugs and used then with no problem. The motor on the compressor should have an overload reset button.
Old 04-08-2010, 07:50 AM
Old Fool's Avatar
Vince
I agree with you on that point Vince.
My point is that it how does the OP know if it is currently wired as a 120 or a 240?
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 10:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 07:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 03:18 PM
