Air Compressors - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2008, 08:29 AM
Air Compressors
Hey everyone. My name is weston and i own a construction business. I have a question about air compressors. I recently bought a 60 gal Sanborn air compressor. It has 3.7 hp 240 volt 155 psi max and 11.5 cfm @ 90 psi. My question is, Will this air compressor run 3 framing nailers without having to wait?
Old 12-04-2008, 08:41 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
1. Welcome aboard. HR.com is a great and wonderful place where honesty, integrity, liberty, and the second amendment are loved and embraced, and despite the occasional "ford vs chevy" threads, we all get along well, and I think that's unique considering how this site has grown since I've been around it.
2. This post should have been made in the Garage/Tools section, but you're new here, so it's okay. Even people with a lot of posts like me make mistakes from time to time. http://www.hotrodders.com/forum/garage-tools/
3. This might be hard to figure out, but if you can, find out how much air one of your nailers use in a minute, (say, 120 nails a minute, as I think this would be the fastest anyone could nail with one of those). Then, multiply this by the number of nailers you have (3). This figure here is "x". If your air compressor can deliver "x" CFM @ 90psi (what most pneumatic tools run at) then you're golden. 3 x "x" = CFM you want
4. Hopefully the compressor is rated at 100% duty cycle, as there's no worries about needing time for the compressor to sit around and cool.
Old 12-04-2008, 10:25 AM
I don't know much about nailers but I watched a fellow use a rather large one while framing in a room addition on my house and all he had was one of those little pancake compressors, he never seemed to run out of air. If that little thing could run that huge nailer he was using with no problems then the compressor you are talking about would probably hardly even notice 3 or 4 of them.
Old 12-04-2008, 10:59 AM
Strictly Gravy's Avatar
Giggity Giggity
Last journal entry: My 72 Power Wagon - The history part 1
The guys that roofed our house ran 3 nail guns off one of these:
You prolly have enough to run 30 nail guns consistently with that thing.
Old 12-04-2008, 11:12 AM
Exactly what I was thinking!
Old 12-04-2008, 12:29 PM
Nailers do not take much air. Your compressor will easily handle 3 of them.
Old 12-04-2008, 05:57 PM
302 Z28's Avatar
Exactly, they do not use a high flow rate of air, just in gulps. That compressor would probably run several dozen nail guns at the same time.
Vince
Old 12-04-2008, 06:31 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
My NR90AE round head framing nailer uses 0.088 cf/cycle at 100 psi. (It usually gets the job done at 90 - 95 psi). I run it from a portable "5HP" 110V compressor (real HP is less, of course) and the compressor doesn't have any trouble getting ahead even when the nailer is set to contact firing, like for flooring.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
air compressor maintenance CaPrI_MaN Garage - Tools 8 10-04-2006 10:14 PM
water filters/traps for air compressors taylorpontiac Garage - Tools 6 01-01-2006 09:11 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
