Air compressors - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 07:24 AM
Air compressors
Hi was wondering if anyone can tell me is there an advantage to buying a compressor that stands up with the compressor on top of its tank vs the air compressor air tank that lays on its side with the compressor on it if the compressor units are the same size?
Old 01-26-2012, 07:33 AM
Old Fool's Avatar
The answer is no - "anyone" cannot tell you about any question regarding air compressors on this website.
Only OldRed is truly knowledgeable about this subject.
Old 01-26-2012, 08:11 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
floorspace used
Old 01-26-2012, 01:04 PM
Wiki Edits: 31
yep, assuming there rated the same, with the same amp motor and motor type, just floorspace.
Old 01-27-2012, 06:11 PM
Old Fool's Avatar
Please forgive my poor humor
Compressors Terrell460 Garage - Tools 4 02-21-2011 08:03 AM
Compressors greybeard 1900 Suspension - Brakes - Steering 1 05-29-2006 07:21 AM
air compressors burninrubbah617 Body - Exterior 2 01-15-2006 06:34 PM
2 compressors, which should i get? toykilla Garage - Tools 39 11-13-2005 12:33 PM
air compressors ranger28 Introduce Yourself 4 01-19-2005 05:09 PM
