air compressors - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 04:53 PM
air compressors
If Im going to rent or buy an air compressor what kind of psi do I need for a one time primer job only? Any particular models. keep price in mind of course.
let me know, thanks -matt
Old 01-15-2006, 05:28 PM
Depends on the gun you are using. Psi isn't what you really need to look at. An aircompressor will put out the psi needed to power a spray gun, but it needs to be able to maintain it, and store some reserve air. So you need to look at the cfm ratings on your gun and you need a compressor that is rated to put out that much. And the bigger the tank, the more reserve air it will hold. Conventional guns have lower air requirements then hvlp. You don't need a fancy gun for primer. But you should get one with the right tip size for the primer you plan on spraying.
Old 01-15-2006, 06:34 PM
adtkart@aol.com
Check the garage forum. This subject has been covered many times.
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 135 11-01-2014 08:49 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
air compressors ranger28 Introduce Yourself 4 01-19-2005 05:09 PM
