Edelbrock sells an idle speed compensator that may work with a Quadrajet. It mounts under one of the bolts for the carburetor and is adjustable (screws in and out) for how much compensation you need. It does not have enough power to push the linkage and raise the rpm from idle, but if its on when you let off the throttle it will keep the idle higher.
I just wired it in to the same wire as the one running to the compressor, without using a relay. It does not draw much current, and has not been a problem wired this way. When the compressor cycles on, the idle compensator kicks in also. Bruce |
| Idle speed in gear | bigdog7373 | Engine | 2 | 12-30-2010 06:31 PM |
| engine idle speed | gene covan | Hotrodding Basics | 1 | 07-07-2010 09:03 PM |
| 650 Speed Demon won't idle down... | stinky jinx | Engine | 10 | 05-20-2006 09:59 AM |
| What's the proper idle speed | Jag Daddy | Engine | 7 | 11-09-2003 12:11 AM |
| Idle speed. | gm_junkie | Engine | 3 | 10-08-2003 12:47 PM |
