Air Conditioning - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2010, 04:10 PM
Air Conditioning
Hot Rob air is out of business. Need some Help
Does anyone know the total amount of oil the system must have prior to charging with R-134A for the first time.
Old 08-24-2010, 04:13 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
We gonna need to know just what you are working on.
Cole
Old 08-24-2010, 04:17 PM
I am working on a 41 Ford street rod with 350 chev engine.
Old 08-24-2010, 06:03 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Most (if not all) R134a contains oil and a UV leak detector all in one can. Cost about $9.00 a can.
Old 08-24-2010, 06:07 PM
Joe G's Avatar
....Does anyone know the total amount of oil the system must have prior to charging with R-134A for the first time.
If the compressor is a Sanden, and it is new, it already has the proper amount of oil in it. If it is empty for some reason, there is a label on the compressor that states the oil capacity. Unfortunately, if you have a polished compressor that label is usually removed.
Hope this helps...
Old 08-30-2010, 03:11 AM
New Member
Thanks you for the pos ***********L]
Last edited by dinger; 08-30-2010 at 10:34 AM. Reason: Advertising. Please see: commercial posting guidelines.
Old 08-30-2010, 05:39 AM
Last journal entry: A few ongoing projects
The chart I have shows 10 oz for the Sanden compressor, then you want to put an oz or 2 in the receiver/dryer and the same in the condenser.
Not surprised to hear about HRA being out of buisness, kind of saw that coming about a year ago. I've got one of their evaporator assemblies set aside for one of my projects. It bench tested ok so hopfully I'l get a good service life out of it.
Old 08-30-2010, 09:49 AM
SSedan64's Avatar
You can calculate oil charge here>> http://www.sanden.com/images/SD_Service_Guide_Rev.2.pdf
Last edited by 68NovaSS; 08-30-2010 at 11:26 AM. Reason: Advertising. Please see: commercial posting guidelines.
Old 08-30-2010, 11:30 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The link to tech specs and instructions doesn't fall within advertising boundries, link to the manufacturers web site isn't necessary and raises eyebrows...
Semper Fi
Old 08-30-2010, 05:20 PM
SSedan64's Avatar
Sorry about that, I posted 2nd link because it had links to other Info. Oil types/specs, models etc..
Air Conditioning MISFT 1 Hotrodding Basics 12 07-13-2010 04:34 AM
Locate the low side port on a Vortec 8100 air conditioning sys Bigblue69 Engine 4 06-12-2010 02:56 PM
Heat and Air Conditioning Systems Woody31coupe Interior 5 09-10-2006 07:40 PM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 08:44 PM
Air conditioning in 1951 Buick Roadmaster madgift Hotrodding Basics 1 08-15-2004 09:50 PM
