Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air conditioning---Vintage Air with a R-4 compressor
Old 01-02-2010, 04:34 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The new compressor should come with some literature about how much oil should be added prior to running it. If not I would add at least a couple of ounces and add that amount to the total the system requires. The switch on the back of the R4 is a high pressure switch and since you are using the trinary switch from Vintage Air you can ignore it.
Vince
