Air conditioning---Vintage Air with a R-4 compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2010, 03:49 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Just put a serpintine system on my 59 using GM aluminum brackets.
The passenger side bracket is designed for an R-4 pancake compressor,
and I intend on getting a new one as soon as I finish getting the AC lines straightened out. I originally had a Sanden.
What should be my steps to properly get this system charged up??
New compressors are shipped without any oil in them and I am wondering
if I need to clean out the entire system and put in the necessary oil, or if just adding oil to the new compressor will be okay.
Also----on the 134 compressors, there is another switch on the back of the compressor.
Is this a hi-low switch??? and does it need to be wired in a series with the clutch??
Already have a trinary switch in the system, and if this is a hi-low switch, can it be bypassed, or should I use it??
The one I got from a junkyard---to get the hoses routing right---I cannot recall if it had an electric fan or not---was a 95 S-10 and I think those have mechanical fans. So I do not believe this is a fan switch.
Old 01-02-2010, 04:34 PM
302 Z28's Avatar
The new compressor should come with some literature about how much oil should be added prior to running it. If not I would add at least a couple of ounces and add that amount to the total the system requires. The switch on the back of the R4 is a high pressure switch and since you are using the trinary switch from Vintage Air you can ignore it.
Vince
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
Underhood air compressor from A/C parts F&J Garage - Tools 4 07-25-2008 09:56 PM
air compressor FIREBIRDTONY Body - Exterior 20 02-17-2007 05:06 PM
air compressor clean air intake? montea Garage - Tools 18 09-22-2004 07:53 AM
how does this air compressor piping diagram look montea Garage - Tools 13 09-04-2004 04:35 PM
