Air conditoning, changing from mechanical to electrical thermocouple? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2011, 10:15 AM
We have placed the Vintage Air mini gen II behind the seat in a 1932 coupe, and would like to place the controls in a header panel above the windshield. The 4 ft. mechanical thermocouple tube isn't going to be near long enough.
Is there an electrical replacement for the mechanical thermocouple/evaporator thermostat? Or failing that, can someone give us the specifications so we can build one?
Old 07-28-2011, 11:53 AM
ogre's Avatar
the 'Duracell Project'
the new VA units have an electrical control valve, i'd check with VA to see if it can be retrofitted to the gen II.
an option would be to put the fan switch up there and leave the rest of the controls in near the unit.
Old 07-28-2011, 12:08 PM
delawarebill's Avatar
temp controls
needless to say my Tbucket does not have a/c so i'm not up on what your wanting to know... but.. this is for infomation.. the temp bulb used on electric gages is a sensor that changes resistance... a thermocouple sends out a small voltage (mv). in a resistance bulb u can use what ever copper wire u want.. a t/c has to use t/c wire.. if the end of the t/c is yellow its a "K" and use yellow/white t/c wire... if black "J" then used the black/white t/c wire. again sorry if this is waaaaay more info then u needed..
Mechanical to Electrical fuel pump Matador813 General Rodding Tech 5 05-24-2011 06:23 PM
Electrical or mechanical gauges? staleg General Rodding Tech 13 11-10-2008 07:02 PM
Electrical or Mechanical problem on a 350. orvillewho General Rodding Tech 18 05-07-2008 02:26 PM
Mechanical or electrical guages? muzzfactor Engine 6 06-03-2007 06:40 PM
Mechanical or Electrical Fuel Pump lakecityg Engine 5 06-21-2003 10:27 AM
